Scarlet fan upgrade - bottom plate issue
J. C. John
Athens Greece
www.decoyimages.com
Greetings,
Just bought a Scarlet dragon brain with both fans upgraded. I do have the Action products riser plate W/ 15mm rods inserts from my previous MX set up.
The problem is that I can't get the 15mm inserts to fit due to the fan extended protector. I know a lot of you went through this and I was wondering was
is the best solution fixing this.
Thanks!
For those that use the 15mm RED plate, you would send it in and they would modify it. However, since that's a 3rd party bit I would either:
- find a machinist
- get a Dremel
- purchase a new solution
Try to buy version 1 of the front fan, wich is smaller AND has better noise performances than version 2.
FanPlate would also be a good add on for better noise and heat performances.
Pat
