Scarlet Dragon Low Light OLPF histogram seems off
jake southard
Beverly Hills, CA
www.jakesouthard.net
I just installed the low light OLPF in my Scarlet Dragon, and now it seems like my histogram peaks on the darks WAY easier than it peaks at the highlights. My camera is telling me the image is underexposed when its clearly, NOT underexposed... is this normal?
Weird. Do you have the right OLPF setting turned on in the menu?
Also, maybe a screen shot of your screen might help so we can see what's going on.
Yes, i have that setting turned on, heres a couple screenshots: shot of the fountain is not underexposed... and when I shot directly at a lamp, its telling me its BARELY overexposed?? It was way more sensitive before I put the Low light OLPF in i feel like...
Feeling is one thing, but we need to lock down what you are experiencing here.
Hmmm. Okay. Well the clipping meter on the lamp seems to be in bounds, which means if you lower the ISO you should see detail there. That would be a nice visual test. While in that same spot with the same aperture and shutter speed lower that down to ISO 250 and you should see texture there. That looks to be "working as expected".
Seems like something is crushing based on the meter of the fountain. Looking at it from here it's really hard to tell what would be crushing. I see the blue channel is moving down. What type of light source is this out of curiosity? I suspect it's crushing in that center area, maybe grab a small light and experiment with what's going on.
