Casey Green
- Feb 1, 2007
- Los Angeles
- www.redcamcentral.com
Thanks, Jarred. This is fantastic.
Will these new firmware and REDCine-X builds support the REDRAY player plugin?
I currently have to run multiple versions and the older version that supports REDRAY doesn't support Dragon...
Many thanks,
Many thanks,
Sneak peek Alpha builds for you guys... this opens up another lane on the ROCKET-X card to give a 20% speed boost as well as adds Monochrome support and AJA IO 4K and Kona 4 support.
This is Alpha so it will likely crash along the way.. specially if you are using a HP Z620.
Rocket-X driver 2.1.16.0 + firmware 1.3.17.0:
* Up to 20% speed improvement
* Added support for Mysterium-X & Dragon Monochrome
* Stability improvements
Known issues:
* BSOD can occur on Windows when installing the driver. Installing the driver a second time should fix the issue.
* Potential incompatibility with the HP Z620
http://red.cachefly.net/rocket/RED_Rocket-X_Installer_v2.1.16.zip
REDCINE-X PRO 31.1 Alpha:
* Added: Rocket-X Monochrome support.
* Added: Support for AJA Io 4K and Kona 4 (Note: removes support for Kona 3).
* Note: Rocket-X support requires driver 2.1.16.0 and firmware 1.3.17.0
* Fixed: Issue with OpenEXR upscaled exports when using CUDA.
* Fixed: Issue with QuickTime mono audio layout exports.
* Fixed: Issue with Avid external audio exports.
Mac:
http://red.cachefly.net/redcinex/ap...E-X_PRO_Build_31.1.34964_OneOff_For_Alpha.dmg
Windows:
http://red.cachefly.net/redcinex/ap..._Build_31.1.34964_OneOff_For_Alpha_64-bit.msi
http://red.cachefly.net/redcinex/ap..._Build_31.1.34964_OneOff_For_Alpha_32-bit.msi
