Nir Shelter
- Jan 27, 2008
- Age
- 47
- Sydney Australia
- www.datashelter.com.au
In an attempt to figure out the best way to export 2k footage whiles maintaining the highest level of color depth and resolution. I experimented with the same shot in Redcine and FCP exporting using different codecs. The results are confusing.
First export:
Loaded the shot into Redcine and decided on using the first 67 frames of the shot. It is of the back of a person wearing a blue sweater the woven threads give a good degree of detail to work with. I exported the clip using a set quality of lose-less, ratio of film2K and all in Quicktime. I then exported once using Proress HQ and once using Uncompressed 10-bit.
Second Export:
Loaded the H proxy into a FCP time line and exported the same 67 frames of the same shot using the default settings that came up then a second export using Proress 1920 1080 HQ... .
I imported all the above exported QuickTime movies to the same time line. I then identically changed the same parameters to them all to make the amount of detail more obvious, I De-saturated them and increased contrast. I then exported still frames as JPGs at grayscale best quality. Then enlarged the same cropped section (or as close as I could get it with a cropping tool) in each of the frames to bring out the differences in detail.
These are the pics of these frame grabs:
Redcine export Uncompressed 10-bit:
Redcine export Proress HQ:
FCP export Proress HQ:
FCP export default settings:
The left side of the subject's back, the left shoulder and the left arm show the most difference in detail between the exports. As light and dark contrast patches.
The FCP H proxy Proress export has arguably more detail than the FCP H proxy default settings export. Yet it appears as if they both have more detail than the Redcine exports.
Why is this when the proxies are referencing the same data as the clips in Redcine?
And does this mean that for 2K work flow in regards to picture quality. It would be better to work with the H proxies in FCP and export a QuickTime directly from the time line, then out to color or a pro grade?
First export:
Second Export:
