T. Glen Phelps
- Mar 21, 2007
Somebody Load The New Firmware And Give Us Some Sample Shots With Frame Rate Ramping!!!
Black balance doesn't take six minutes to complete, nor is it required before using the camera. I am inclined to believe this is something more complex... but that's just one guy's thought.I assume this is similar to the Black Balance settings on most video cameras.
Much more complex... and it needs to be done.
Jim
Audio Recording and Metering, OPEN GATE mode for RED-EVF, SYNC Mode for RED-EVF, False Color and Zebra on HDMI and PVW HD-SDI, GMT Time and Day with Time Zone offset, Programmable GPIO’s, Interval and Trigger based TimeLapse, Frame Rate Ramping, Black Shading Calibration / Highlight Streak Suppression
Awesome! :gun:
How often does it need to be done? (Only once... At the beginning of each project... Or each time a lens is changed?)
It only needs to be done once but it's very important to note that you shouldn't go back to a previous build once you've gone to build 12 and run the black level compensation.
A few questions:
(I have enabled audio)
Is audio recorded as a seperate file or embedded into the .rd3 file?
Does in-camera playback support audio?
I do not get audio playback in camera and dont see any audio files on the CF. I can hear the audio when recording and see audio in the meter.
EDIT:
Ok stupid, the audio is embedded in the QT files.
So it appears that in-camera playback is not yet supported.
BTW- I am occasionally getting noise in the headphone output. I cant seem to replicate this since it first happened.
EDIT 2:
Noise is back- camera took 2 minutes to boot and now has noise in headphone out.
EDIT 3:
hiss is also recorded.
