REDCINE-X Professional Build 5...
On Epic 5k RC7:1 29.97 footage, I'm having audio sync issues. Audio is sped up. On quad core Mac with 12 GB ram and RR card.
Anyone else have this?
I did not have this with beta 4.
Anyone On a Mac having Sync issues with this build?
Has any noticed RT playback with audio is wonky? I.E. sounds like the audio is sped up while footage plays back at the right speed...
Can you guys please email me both (rob at red dot com)? I need to take a look at a clip that shows this problem.
Thank you!
Hi Guys,
Can anyone point me in the right direction to find training and/or tutorials on how to use RedCine? I've searched the forum and can't find it. I did find the old tutorials but the interface looks totally different.
Thanks in advance.
Joe
This version crashes when I put Epic footage in the viewer either by double clicking on the thumbnail or dragging it into the timeline. RED footage plays fine.
Spike,
I've tried to duplicate this issue you are seeing but having no luck. Can you email the Crash report and RCX log to redcinex at red dot com? Thanks.
Armen
Hi Spike,
I would recommend trying to remove your RCX Library. If you have grades that you have saved you can back them up first
navigate to :
Users/YourUserNameHere/Library/Application Support/red/RedCineX
You can either archive and compress what is there and save it as a backup, or trash it.
If you don't have any looks you've created that you need to keep or anything, just trash it.
Then Restart redcine X Pro, it will create a new support library there, and you should probably be okay.
Are you using a Redrocket?
Dan
Not using a rocket and I tried clearing everything in that location to no avail. Sent the logs to you Armen. Thanks for the help. I'm on a macbook pro at the moment. OSX 10.6.8
Anyone have an issue where the new Post Look - Unsharp Mask get greyed out/unselectable? It was working initially, but now it's not selectable regardless of the clips I load up... is there a setting that disengages it or something?
Mike,
Unsharp Mask is intended to be greyed out in Build 5. Not sure how you were seeing it enabled. If you see it again, send a screen shot to redcinex at red dot com please!
Thanks,
David
Will do... I think it was on my initial boot up and/or up until I restarted my comp since I first installed. It was enabled though... I'm not crazy... i'M nOT CrAzy.
I'd third a resolve tutorial.... Redcine has spoiled me. Lightroom is amazing to use => redcine is amazing to use... So many other things arent yet! (learning 3cp and resolve at the moment, myself -_-)
Like everyone else I am very excited by the prospect of using these new post look effects, but I can't seem to preview them on my rocket output to be able to judge my application of them correctly. Are you able to view them on the rocket output or is this something that is coming in a later build or even not possible?
I am also still having issues with the still stores not working/displaying on the rocket out. (Rocket driver 1.4.15.0 , Firmware 1.1.15.4) Do I need a firmware update for this RedCine-x pro build or am I up to date? Anyone else struggling with this issue or has everyone switched to monitoring via a second computer monitor out instead of directly from the rocket?
Like everyone else I am very excited by the prospect of using these new post look effects, but I can't seem to preview them on my rocket output to be able to judge my application of them correctly. Are you able to view them on the rocket output or is this something that is coming in a later build or even not possible?...
Hi Quentin,
This is what Deanan said:
All the post effects happen once the image comes back from rocket to the host. Clarity and film grain will be the slowest but alchemy should be pretty fast.
We don't have a way to send it back out through rocket and not sure if that would be viable.
All the best,
