REDCINE-X Professional Build 10 Beta...
Status
Not open for further replies.
has this version a limited use of alchemy?
when will be there a redlog2rec709 lut for davinci, avidmc, fcp7?
(i know you dont like it, but like log C has workflow papers, plugins etc so their log C looks nice in the named softwares)
will there be gpu debayering anytime soon? ( i have the rocket, so its not for me, its for all the dozen clients i have who shoot with several cams including the epic, who dont want to wait 60 hours for a 4 hour footage transcode -note :90% of my clients use avid, 7% fcp7,2 % premiere and 1% fcpx)
it doesnt make sense for them to buy a rocket.-edit: at that price...for 1000 who knows
and scaling UI is a little bit of a hassle :)
Is there anyway you can add the function to REDCine that in the ETA section when rendering (exporting) it gives the real time it took once the render is complete? So the ETA is cool when rendering but when finished it gives the actual time taken for the render
I have a REDlogFilm to REDgamma/REDgamma2 plugin available for FCP7 at www.antlerpost.com/plugins if that's what you're after. It is also available as a LUT for Apple Color. Other versions coming soon.
hi nick, yes pretty much something like that! will there be luts especially for davinci and workflow papers or plug ins for avid too?
i like your plug in for that other cam :)
Hi Nick - your BUY site doesn't seem to specify a FCP PI, just Color...
On the store page there are separate PayPal "Buy Now" buttons for the plugin, the Color LUTs and a pack of both.
I already have a preliminary Resolve LUT, but want to do further testing before I put it on the store. Like the Alexa plugin, my RLF2RG plugin comes with a user guide with workflow information. I am also writing an article at the moment about log workflows in general. An Avid plugin is more complicated, as there is not an Avid equivalent of FCP FXScript. I have experimented with using a custom curve grade as a LUT in Media Composer, which does work.
RCX Pro 10 is slower as the previous version on my computers...
Can't play in real time with the Red Rocket... And the MXF transcoding are very slow, like without a RR !!!
Always the same problem with the AFF files... They appear randomly when exporting MXF.
You know that if Alchemy is on then you render in the CPU's... could be your problem.
Not sure if this has been mentioned but the still store doesn't work properly (on 9 or 10). When you hold the number of the still it stores the image of the frame. Then, you can play the clip in the viewer or adjust the grade. Clicking the number to recall the still toggles the still store function and recalls the image but clicking again does not toggle the still store off. The still store image is still displayed, even though the number is lit up. You have to navigate on the timeline or use arrow keys to advance the play head to refresh the display with the clip in the viewer and not the image in the still store.
Please have a look and fix this because in grading dailies we rely on an easy to use and functional still store. Thanks.
OUPS...
Indeed, the Film Look was enable... It's the reason why it was very processing consuming... My mistake !
So, it's much quicker as the previous versions... Incredible ! :patriot:`
But in 25f/s and with sound, the problem is not fixed... Impossible to create AAF files for DnxHD transcoding.
This is a problem with the Avid DNxHD SDK that we use. We can't fix that on our end. Hopefully we'll get an update soon. In the meantime a solution would be to export video & audio separate and loading both assets in to your Avid.
OUPS...
workaround:
export 25p mxf without sound + BWF files of the same clips from rx.
takes only a couple minutes more and both tracks autosync perfectly in avid.
hope that helps.
edit: robcode was faster hehe
Status
