REDCINE-X PRO (Beta) v40.0.0
I have already installed the previous versin on my Mac, do this will update automatichally the previous version once is downloaded? Thanks
Luca,
This is a Beta, so it will not update automatically.
Anyone test out the Cuda performance improvements; are they substantial-teetering-on-magical? (also did the min-req go up?)
Any way to scale text size for 4k monitors? Other software will scale to personal settings set in Windows but Redcine won't.
I'm on Win 10 -I'm being told after download "The signature of Redcine-X_Pro_Build40.0_Beta_64-bit.msa is corrupt or invalid. Anyone else seeing this? I've tried a couple times now with the same message.
This is pretty common, it basically just means that Windows has no way of identifying where the file came from. If you run it you'll get a warning about installing mysterious software; if you click the "more info" link you should get a "run anyway" button that will allow you to install it.
Had this issue on v39 as well: Export Presets: Burnin Tab: attempting to type in one of the burnin text boxes has been crashing the program. Modifying existing presets as well as creating a new one.
Issue remains in v40. Using Mac Pro and MacBook Pro on El Capitan. Really miss typing in custom burnins!
