Job ter Burg
I've installed a RedRocket card in an HP XW8600 2x QC 3.0GHz with 8GB RAM under Vista Business 64-bit SP1. I'm primarily using it for use with Avid MetaFuze. I installed the drivers and firmware that came with MetaFuze (as recommended per Avid).
I was interested in investigating RedCine-X. Downloaded it today, but when I run it, I get a few error messages. One is saying that the RedRocket has firmware 0.0.0.0, and I should install at least 1.1.4.something. Then it tells me that the Rocket is on a 0x PCIe speed slot and cannot be used (it is in fact in Slot 4, whcih is PCI-E(2) x16 mechanical, and set to x8 electrical via system BIOS. Then it tells me that the Rocket will be unavailable in RedCine-X because of that. Then it tells me again that the Rocket has firmware 0.0.0 and I should up it to 1.1.6.something.
I downloaded the current driver/firmware package, installed the new firmware, but still get the same errors.
Does anyone have a clue for me?
