- Admin
- #1
- Dec 27, 2006
Enjoy
REDCINE-X PROFESSIONAL BUILD 31 BETA
https://www.red.com/downloads/4f56854e6261f95a570006af
[h=4]CHANGES IN THIS BUILD[/h]
- Added: Dragon Enhanced Blacks (D.E.B) control (CPU/GPU).
- Added: Support for iXML timecode metadata for BWF audio auto-sync.
- Added: Colors in the export tab status column to represent state: green for finished, yellow for processing, and red for abort/error.
- Added: Additional columns in the export preset table to show format, resolution, framerate, and output folder for presets.
- Added: Ability to select multiple presets in the preset table (to delete, move, or export).
- Added: Keyboard shortcuts for Snapshot and R3D snapshot.
- Added: Keyboard shortcut ALT+left and ALT+Right that sets offsets audio sync by +/- 1 frame in the audio tab.
- Updated: Restored ability to export mono audio tracks in QuickTime.
- Updated: When scrubbing from the timeline, allow scrubber to snap to slugs and markers.
- Fixed: Issue where Rocket was not being utilized for certain Fit cases.
- Fixed: Issue where you could not prompt for filename with JPEG snapshots.
- Fixed: GPU scalar issue with aliasing on certain aspect ratios.
- Fixed: Track selection is maintained in the audio tab when switching clips.
- Fixed: Crash when ejecting media with a clip open in the viewer, or deleting a clip that was open in the viewer.
- Fixed: Issue causing JPEG exports to run slower than they should.
- Fixed: Issue with incorrect in/out points when importing FCP XML.
