Bob Gundu
- Mar 17, 2011
- Toronto, ON Canada
- www.10fh.com
You'll see bad footage soon enough from the R1.
Exact same sensor, exact same dimensions at a given resolution. Differences include: Scarlet can do 5K (full sensor), albeit at low frame rate, R1 can't do 5K at all. R1 can do 4.5K at higher frame rates, Scarlet can't do 4.5K at all. R1 also shoots at RC28, 36 and 42, which translate to higher compression ratios (around 8:1 to 12:1, if I recall) than the lower compressions of Scarlet.I don't believe the scarlet uses the full size of the sensor.
I can't quantify it... but footage on the red 1 does look a tad better than the scarlet. Just watching video comparisons of the two makes me think the r1 looks a bit more... robust
OK, found something.. This is a very well elaborated test with a PDF download.. check this out..
http://alfonsoparra.com/en/press/cat/research/202/Epic-Photographic-observations
Interesting, however I think the Epics image is superior to Scarlet, again just from what I've seen. Either way I'm getting a Scarlet and will do some tests to try and produce the best possible image
Again .... any article? any link?
Better Buy a Scarlet BC the ONE MX is Sold out.
Zeiss Super Speeds MK III
