Tom Dowler
Hey all,
I'm 95% ready to pull the trigger on the Scarlet-W and just trying to figure out monitoring options.
I was shooting on an Epic Dragon last week and the 5" screen was definitely too small, so I'm definitely looking at the 7" monitor. I'm also not sure if I love the idea of touchscreen or not.
So wanted to see if anyone had any input on ditching the Red monitor altogether and going with something like the SmallHD 702 on a noga arm in combination with a side handle/sidekick/foolcontrol for control of stuff.
From what I can tell, each approach has pros and cons:
Red 7" monitor pros:
Any other thoughts on this? I think through the process of typing this I've talked myself back into the Red monitor but curious for thoughts.
- neatly integrated (no trailing cables)
- mounts easily directly to the brain
- touchscreen gives you an extra control interface
- more features - waveforms,
- brighter than the Red monitor ?
- decent lens hood available
- can be used for other cameras if needed
- quickly change LUTs/views
- trailing SDI cable AND trailing tap cable
- takes longer to attach/setup
