Excellent examples, Florian. A good illustration of some of the things colorists and others have been talking about, but a bit more scientific.
Hi Jake
It is not going to make any closer to Alexa in terms of skintone. The color dictates by the sensor, filter usage, method of debayering and color space.
Alexa recording needs to have matrix apply, any transformation need to have LUT. But RED footage is different, it happens during the debayering process, and you can select it on your own preferences. Which what you are trying to suggest to have LUT and have it transform outside RED realm.
In Davinci, it exists 3D logC to rec709, but let's take a look at Graeme opinion in the previous post
Graeme's post :
Just think back to earlier in the thread where Deanan mentions how Sony sets their red response filter characteristics wide to allow a lot of red through, Arri set their's narrow to let through less far red and RED set their's inbetween. If all three camera types record some deep far red colour - the Arri might not see it at all, the Sony sees it all and RED sees it inbetween the two. Now there are very valid reasons for why each camera manufacturer sets their response where it's at, but no LUT, IDT or matrix on this planet will make the Arri see the red it's native spectral response cannot see to match the output of the Sony which can see it. That is why, in one particular example, why you'll never get the same spectral response via ACES or any other colour space. Of course, three tristimulus values of a colour in a colour space will only ever approximate the actual spectral response of a colour under a real light with a real spectrum anyway....
It involves other thing rather than mere color space. Characteristic of the sensor comes into play too...
my 2 cent
PS. Florian, if you can help to upload the data for testing purpose both RED and Alexa original footage, it will be great. I can help you to host the files if needed.
Rivai
Hi Jake
Yes, the Davinci logC to rec709 i believe comes from arri themselves which implemented inside davinci. So if you have logc footage that u need to transform to rec709, you are free to use it in the 3D LUT section.
BUT this doesnt restrict you to apply to other footage ALTHO it is not meant to be. Like what you pointed out. You can use it with RED RAW which has RLF and RC2 setting. Apply logc to rec709 from the grading node. RLF is a cineon standard log develop by RED, it will be a bit different from logc. but RLF is still log
The proper way to view RED footage in rec709 is of course to use rec709 color space from the raw color space setting itself, so you are not doing it outside red realm.
I believe the skintone will not make any much difference, i wont be surprised if it look worse. What people here seem to miss is, the fact this discussion is about skintone in particular. It diverts to overall look of the camera, which cant be help, but it's really about skintone from the beginning.
What i try to understand now is, looking from the color chart, which section of the color that represent skintone ? I dont think red or yellow alone represent the skintone color. That is why skintone subject is very complex
Rivai
I also remember a discussion on David Mullen's thread where he was talking about how skin tones usually also play a large part in the lighting temperature (as mentioned here), make-up and grading.
I'm linking some images made by Gunleik Groven that he posted on his Epic test thread:
How about a skin tone shootout at RSH?
Point an Epic and an Alexa at a couple models with different skin types. Put the images on the big screen side by side. Keep the actual models on set directly adjacent to the screening (lots of duvetine to prevent spill washng out the image) so we can see the way their skin looks in real life and compare it to what's on the screen. Would be nice to see both the "default" image and what a proper colorist can do to match each camera's output to the models...
Cheers - #19
Florian - if you look at the skin of your hand holding the chart, it looks a better on the Alexa. Look at the subsurface scattering and subtle red shades on the fingers!
I know a lot of people who "don't like RED color" or say "Alexa rocks" to which I respond...
1. You're an idiot
2. You just don't like RedColor or RedColor2 or whatever default processing they used for the dailies.
3. Wait till they grade it
4. RED does seem to be trickiest when working with the red tones though. Trick is not to clip anything. Expose to the left. And give the poor ol' blue channel a chance. Shoot daylight or try a blue filter on the camera if you shoot tungsten.
Except that alexa cuts off most of the red response so it's doing the exact opposite of what you're saying.
So what makes the skintone stands out ?
EDIT : Looking back at the chart. The red color from alexa seem to match EPIC red color.
I think that depends on your perspectives and prejudices. I've seen enough epic vs alexa tests (they just won't stop with the tests) where epic has been as good or better than alexa.
There one particular test where people insisted that they didn't need to test epic because alexa had better skintones. They tested and epic won the skintone test. This was for Victoria's Secret, Every skin tone and shade you could imagine on real life models in real shooting environments under different lighting, daylight, strobe, tungsten and HMI.
