Mike Prevette
Are you using the RED base or the ARRI base more? I would think for you the Arri one would make more sense, you should have your case set up for that always on. (sorry it's hard to turn off the inner AC in me)
Hate to burst your bubble but apparently they are a few MM off. I had Matt Uhry check that out for me and confirm. The ARRI sliding plates do not fit the Red base. In my opinion it's the biggest mistake they made with the accs.
If you can't afford to ship these cases you probably cant afford what should go inside them.
The Arri dovetails don't fit into the RED bottom plate. Those RED Arri plates are a lifesaver.
although...most of the stuff on the bottom is going on the camera when you open the case, so reality is the top level is the stuff you will be looking for later.
