Jeremy Ryan
The camera. With the OMOD and the v-mount (I assume) and a hypercore will be a good 5 feet long off the back there. The Mozegear is a much improved better version of a WC A box.
Just go through these pics: https://www.flickr.com/photos/85198244@N02/
Hey Jeremy you mentioned using the Mozegear mini-papi with your RED and that you miss the DSCM camera, but from the pics you shared it looks like you're still using the older RED's. Are those old pics? If so, have you tried using the Mozegear mini-papi on DSMC2 cameras and has it solved all of your audio issues? Thanks!!
Yes. Those are old pictures. We now run the scarlet w and have the mini papi attached to camera through the vmount expander. It's the best, easiest, lightest run and gun option that we have found to date with phantom power. You need some extra cables though, but they're cheaper cables. I will take pictures as soon as I am home. 10 days out.
I believe you can just hook the lavs direct in to the expander 3.5mm because you really don't need the preamp and phantom power with lavs as they are battery powered. If you do need it though, the mozegear would work essentially the same way. I did ask Mozegear why the TA3 connection instead of 3.5mm and they said they wanted it to lock tight in there to keep a secure connection. And when I think about it, that is a good idea.
I've attached a wireless lav to the v-lock and got pretty bad results. I'm wondering if it's the module or the a-box..
could be, whats the source
steve
Quick note: be sure and check the manual for your particular setup - particularly the Base Expander audio jacks - to be sure your TRS (tip, ring, sleeve) assignments are correct. See below copied from user manual:
STEREO MICROPHONE
The following expanders feature a stereo microphone jack:
DSMC2 Base Expander DSMC2 V-Lock I/O Expander
The 3.5mm stereo microphone provides two (2) channels of audio for recording.
PIN SIGNAL
TIP LEFT
RING RIGHT
SLEEVE GND
Be aware that if one of the three "lanes" is unoccupied it can provide an opening for EMF intrusion.
Be aware that not all microphone/mixer source leads will have 1/8" mini plugs that use the same tip/ring/sleeve assignments.
Cheers - #19
Hello Jeremy,
Great find with the Mozegear Mini Papi. I'm on their site right now and I'm wondering which version you purchased, Papi A, Papi C or Papi X? You keep mentioning using a TA3 to 3.5 adapter but the Papi C which Mozegear recommends for RED users, is a TA5 output. Also, I see only one XLR input for the Mini Papi. Does this mean you're using two Mini Papis, one for each channel? Thanks again for the find. I use an A-Box but I believe it's faulty. I keep getting interference now and again, but I always have an audio tech recording to an external cause RED audio is unreliable. Even still my clients get annoyed I'm not getting good audio in camera and they have to sync to my audio techs backup (not really a backup though, it's the best audio and what RED records is scratch). Also who did you purchase the Mini Papi through?
