Rear SSD Module
Jarred Land
Fire Chief
Staff member
Come see working in our booth...
Pre-order tomorrow. $1250. Ships June 1st.
Does this provide a backup recording if you also use the side SSD module?
Any chance of a picture?
Does this have LCD/EVF out on it? Would be interesting as a way to make the camera slimmer (get the EVF closer to the camera body for shoulder mount) and longer for better weight dispersion.
I doubt it. That would defeat the purpose of the LCD/EVF +1 module.
Also, the EVF sits right where it needs to be, at least with the EVF spinner attached to a rail on the side of the top plate.
Is there a choice of Left and Right orientation of the slot? I want two for side-by-side stereo :)
How many can you use at once?
Can you use this and the side module to hot-swap?
Can I remove the Side SSD Module without voiding the warranty, use the Rear SSD Module, +1 Module Adapter, and Pro I/O and get the same SSD functionality and both LCD and EVF working properly? My intention would be to slim up the camera and disperse the weight back for better weight dispersion front to back and better center of gravity. This would also allow a little more room for the EVF mount and overall be more comfortable in shoulder mount.
absolutely....
Can you combine 2 for double SSD action for endless recordings? Also with the combination of the side SSD + rear SSD for endless ?
