re: Looking for simple "One light/best light" processing of raw R3D files
derekmok
New member
We have a job coming up next week where the deadline is extraordinarily tight -- shoot on one day and editing on the next, presentation on the third day. We will have 60 to 90 minutes of footage shot on RED (likely to be 4K, 16:9) and we are trying to find out a few things:
1. The producer believes there is a way to use either RedAlert or RedCine to do a simple "one-light" or "best-light" processing of the footage without messing with in-depth colour correction, a preset of some kind that would preserve the settings chosen during the shoot. Is this true? If so, how do we access it? I looked through the RedCine interface but couldn't find such a preset that would allow this kind of automatic processing.
2. Using an Octocore MacPro (unsure of amount of RAM), how long would it take to transcode the raw R3D files to ProRes HQ, 720p24? We can't use FCP Log and Transfer or edit the R3D natively because the primary editing station is still on FCP6, PowerPC G5.
3. The final deliverable is not HD; it is SD 720x486, DigiBeta. We are currently thinking about whether we need to go from R3D to HD to begin, whether we should simply go directly to Uncompressed 10-bit SD. Is there any downside to this, other than the inability to shift the frame around using the leeway offered by going to 720p or 1080i? Would going to SD at this early stage save on processing time?
Any information would be greatly appreciated.
Get Clipfinder (free).
Use the look set in the camera or create your own first-light in Clipfinder.
Process to uncompressed SD in 10 bit, that's OK.
What I don't understand, is how do you plan to do the final color grading? You do plan to grade the edited master, right? Are you going to do it on your G5 with Color? And what do you mean by "shift the frame"? Are you talking about resizing the frame? If you do, then you should do it from the original 4k. By the time you scale it down to SD, any blow ups will be less, than optimal. You can finish it as HD and then at the very end just export it as interlaced SD size for the DigiBeta recording. Just make sure, it's 23.98. And, no, there is no automatic preset for "one light" grade. Only color space and gamma...
Just to clarify... because the difference is huge...
One light means one correction for all, so quick and dirty...
Best light is color correction for every individual shot...
it is a day and night difference for 90 minutes material...
