RAVEN Operation Guide
Jason Bodnar
Seattle
I see WEAPON/SCARLET-W guide was released last week, any ideas when the RAVEN operation guide will be available? Or are you guys still adding some surprises for us ;)
Likely really, really soon.
Remember though, operating a Raven, Scarlet-W, or the various flavors of Weapons are alarmingly similar. If you can get familiar with one, it's fairly easy to dive into any other.
Thanks Phil...I was mainly wondering if we would see the same max fps that SCARLET-W saw 400fps at 2k 8:1 ;)
Jordan the 2k 8:1 at 400fps is off pg 81 frame rates table of the latest operation guide release for WEAPON/SCARLET-W, just wanted to verify this is correct and if so will RAVEN do the same as I also thought 300 was the max.
keep in mind 400fps is probably possible but thats at an aspect ratio of 8:1 not compression of 8:1. So basically pointless
Good call was reading fast and it is likely 8:1 ratio....that said this was shot 8:1 and is very interesting. Not ideal, but if possible, will take it for those experimental times ;) https://vimeo.com/104297856
