Aaron Lochert
I don't have a Gemini or had the pleasure to use one yet.
One thing I was thinking about when discussing resolutions in another thread is this:
According to phfx.com, 5K 1.7:1 uses the full sensor recording area of 5120 x 3000.
If you shoot 5K FF, it's not actually the "full frame". It's named as such to match the aspect ratio 1.9:1 of other RED formats. So then FF doesn't mean anything but 1.9:1, right? But then you have the Raven who's 4.5K FF mode actually does use its full sensor and is not a 1.9:1 format. So what does FF mean? Full sensor recording area or 1.9:1?
So then you have 5K HD, which makes a 16:9 crop of that non-full-frame FF format, resulting in 4800 x 2700. This matches the exact same pixels of other 5K HD formats. But is this important to anyone? No one is delivering 4800 x 2700 projects; if we're shooting 16:9 it's because we're all downscaling to UHD anyway. Since we have the sensor height, why not have 5K HD shoot a 5120 x 2880 extraction and have maximum downscaling ability for UHD?
And then 5K 6:5 actually does use the full height resulting in 3600 x 3000, where other cameras with 5K 6:5 shoot 3240 x 2700.
But then 4K 6:5 does not take advantage of the tall aspect ratio sensor, instead matching other RED 4K 6:5 modes and recording 2592 x 2160. So the difference from 5K 6:5 on Gemini to 4K 6:5 on Gemini is a huge crop.
It's incredibly inconsistent.
Not to mention this has implications with framerate ability. 5K 6:5 on Gemini won't be able to hit the same FPS that 5K 6:5 on the other two DSMC2 cameras can because of the added vertical height. But 5K HD across all DSMC2 cameras will.
Maybe the naming conventions need to change. Or maybe we need a toggle switch between "Maximize Resolution" and "Maximize Framerates," meaning if you enable Resolution, you get access to all the resolutions that make use of as much of the sensor area as possible due to the aspect ratio. And if you enable Framerates, you crop in on the sensor as they're doing now with most of the formats (save for 5K 6:5).
Or maybe we just need the ability to dial in whatever recording area we need and let the camera tell us what the maximum framerate we can do with it.
Or maybe we don't, am I thinking too far into this?
I feel like if I shot with this camera I would just shoot 5K 1.7:1 and take whatever extraction I needed in post to avoid all of the confusion.
