- Banned
- #1
Giac
Banned
I'm working with 2 cameras with build 30.5.0; while one is working perfectly, the second one is giving problems:
- shows "sata trans fault" error
- when in playback mode says that the clips are not playable
- doesn't finish the POST, and sometimes records just few frames and stops automatically.
I tried to change the drive cable (I was using the 6ft one) with a 18inches one, but this solved just some of the problems: still doesn't finish the POST sometimes, and other times records few frames and stops automatically.
I tried also to reinstall the B30 but this didn't change anything (by the way, someone told me that reinstalling the firmware may CAUSE problems. is it true?)
the camera works perfectly only when shooting on CF.
any ideas???
thank you very much!
any ideas???
