Alex Lubensky
- Nov 18, 2016
- Kyiv, Ukraine
- vimeo.com
I have a project where I need to shoot timelapse stuff during a period of a year (several days a season). It's on a countryside, so no access to power supply nearby. The thing is that it draws battery too fast, especially when the shot takes 8-10 hours to take (shadowplay or smth. like that). It was not a huge problem changing batteries when it was warm outside, but I suppose it will be when it's cold outside.
Right now I'm powering from a V-Lock batteries, 190Wh. They last almost 3hrs in a warm period, but today I was shooting at 0 degrees Celsius and they lasted only for a 1,5 - 2 Hours depending on the LCD brightness. When you need to run for 12 hours non-stop, it'll take too much batteries overall in a cold period (I suppose more than 6 190Wh batts during wintertime)
I'm concidering to somehow charge batteries or power supply my Red Scarlet MX from my car (fortunately in a non-snowy period I can park it right near the camera). From my research, there are 2 ways of bringing power supply from my car, each has positives and negatives.
1) Powering the camera directly from a voltage invertor using a RED DC power adaptor. There are two types - one offering power from a 12V power outlet inside a car, and can transform approx. to a 100-150 Wh source depending on car internals. The second one should be connected directly to a car's accu, delivering power up to 2kWh, but draining your accu even when the car is turned on and the internal generator running.
Has anyone tried to power your camera from a car invertor? What to look at, which type of invertor to choose, how much WH do you actually need to be safe? I know my RED Scarlet uses approx 60WH during normal operation, but how to prevent your camera from a damage, if anything fails (like engine suddenly stops, or anything like that).
Positives: You can run your camera at no limit, no need to change batteries (distract the camera positioning). You dont stress the image while changing batteries.
Negatives: Possibly not that safe power supply for a camera.
2) Powering my V-Lock battery charger from an inverlor. I have a SWIT SC-302S charger. The input is AC 100V-240V 50/60Hz. Nothing else is stated by a manufacturer. Therefore I have two ways to charge - I can charge batteries one by one in a car, powering camera from a fresh battery, or I can connect my camera over a D-Tap connector to a SWIT charger and run the camera from a D-Tap (meaning I connect D-Tap from a charger to a Power Supply Port on camera). I guess this is a possibly safer way to power a camera, but in the first case it still needs a plenty of batts (190Wh charges to full for approx 6hrs), and in the second case i'm not sure is it safer somehow, then powering your camera directly from an invertor.
Positives: You can safely run from batteries
Downsides: You still need plenty of batts.
I don't concider a proprietary generator because of several reasons. If you'll take a small one - it won't last for a whole day period, and you will have to refill on the go. I don't thing it's a best idea. Besides, it's one more thing to bring with you, and I don't like it - it smells, takes space and so on.
The Car is Skoda Fabia Combi 1,2 BME. The generator is made by Valeo, it's stated it runs 14V and outputs 70-120A depending on a model (can't find which one is mine as of now).
I'm located in EU region so 220V is my religion.
