Power Window
Brian Bradley
Oakland, CA
www.brianbradleyfilms.com
I have a Newbee question. How do you delete a single point from Curve path of a closed power window. I created a grade in one of my clips which included a power window. I copied that grade to another clip but the curved power window has too many points. I've tried option clicking, command clicking with no luck. Also how do you completely delete a power window that you've created?
Thanks in advance,
Brian
Middle mouse does delete a point. Double-click turns a curved point into a straight line point.
Delete a power window by hitting the "reset" button in the Window GUI display, or with the appropriate buttons on the panel you're using.
