Rob Skates
- Jan 7, 2015
After the Interchangeable OLPF System modification, is there a change in the number of pieces of glass (filters, clear or otherwise) or the thickness of the glass and or filters in front of the sensor? We have noticed focus issues in post modified cameras. The flange to focal distance was correct prior to the modification with tack sharp focus. After the modification the flange to focal distance was correct yet there were focus issues that were consistent with several lenses. The lenses were all tested on an optical projector to eliminate the lenses as the issue. We noticed the focus issue with two interchangeable OLPF modified cameras. The focus was off with both cameras by the same degree. It could be a coincidental anomaly. We suspect a change to the thickness of the OLPF or the addition of protective glass in front of the sensor etc. This would create a change in the Effective flange to focal distance in the same manner that behind the gate filters did on film cameras. Has anyone else experienced this with their OLPF modified cameras.
