- Banned
- #41
Laco Zamba
Banned
Redline export not working?
Once this is out of Alpha, will it be available for OSX 10.6 or is it only going to be compatible with 10.7?
great!!!!
is the ultrastudio mini monitor supported?!?!
SDI only or HDMI too?
thanks!!!
I have problem with Export from REDCINE-X via REDLine
In Export preset -> Options -> Use REDLine (software only) I have checked
In Preferences -> Transcode -> Max Simultaneous Export Jobs (REDLine, Snapshots) I have value 2
Export is finishing very quickly without exported files. I'm exporting to ProRes 422
Same configuration is working fine with version 17.26547 on Mac OS X 10.8.3 installed in /Applications/REDCINE-X Professional
Version 18 is installed in /Applications
Ok, thanks. I've been running the 2 rockets in the Cubix for quite a while, seems odd that it doesn't work anymore in the alpha when not using the decklink. How it gets cleared up soon, saves a lot of input switching for me on my monitor.
Tim
"Added: OpenCL processing for Effects. Requires an OpenCL 1.1 driver and a card with 768MB or more memory onboard."
Well, so much for the most expensive Mac Book Pro ever made.... 512MB!
What about a "passes" mode? Or quad processing? Or is that too old Video Toaster thinking?![]()
Tim,
I've been looking at your issue all morning. I've got a Mac Pro 4,1 running OSX 10.7.5 with a Cubix attached and 2 RED rockets inside. I've tried running SDI Output on both Rockets, on a DeckLink Extreme 3D+ and a DeckLink 4K Extreme and am unable to recreate your issue here.
Could you please turn on verbose logging and send your log files in to redcinex at red dot com? Maybe that will shed some light on things.
Also, what rocket driver and firmware versions are you using? What version of the Blackmagic Desktop Video are you running? It should be in the title in the system preferences page. We built the DeckLink support around version 9.7, so it's possible there's an issue with older versions of Desktop Video.
Just checked out the second new build on my Mac. Enabling Video Out kept immediately crashing the app until I went into the preferences and changed the output from the Rocket to the Decklink card. Output seemed to work great. Footage, however, was buffering really slow. My 8 bay SAS RAID is reading at 680MB/s and even at 1/8 debayer, footage was buffering to slow to play real time.
This may be a silly question, but is there any reason it would be preferable to monitor RCX through a BlackMagic or AJA card instead of the HD-SDI out of the RedRocket? Or is it simply the advantage of having more HD-SDI outs for multiple monitors; or as a gift to those users without Rockets?
