Stephen Pruitt
I want a smart mount with wireless to use as a follow-focus. . .
Stephen
Stephen
I wonder if RED will be Santa Claus........
It is strange that Andy hasn't gotten back.... Maybe Red did buy the mount or Andy....
Is Alex aware of the "burning motors" issue and has he addressed it?
???What is that?with an (industrial version) Birger mount
Yes, please.couple of things still left to address.
1) cables, right now the controller has an integrated cable going from the
controller to the lens mount, and controller to the AUX power port.
I want to replace this with a connector on both ends, thereby giving you the
option of longer cables if necessary to attach the controller in other places outside the camera body.
A plate on the back would work well. Need both a 19mm rod version and also a flat version with 2 holes -- to mount to an ET cheese plate -- version. OR... make it like the ET EFV mount which has a rod and the flat 2 hole all-in-one piece, that would be excellent3) Mounting options? Right now.. I'm using the power of "velcro" to get the job done. but planning on some strategic mounting holes / bracket to attach to rods? what would you all like to see?
Where did this worry originate? Has anyone ever burned out a focus motor on their SLR lens? I've heard it repeated several times now on Reduser, but I've never seen any proof that it's an issue. We run Canon L lenses with an (industrial version) Birger mount, and have never had a problem.
Consider that these lenses are designed to be in continuous, professional use, constantly autofocusing.
