Zeb B
dont be a pussyjust like changing the the lens mount 4 screws... its pretty hard to screw it up.
Quote of the week and words to live by
Don't know if it would work, but…
perhaps a magnet mount, kind of like on the power connection on the MacBooks… Seems like a fast, secure and flat/even option.
Just an idea…
Cheers - #19
I Agree. After all, Jarred said tolerances are measured in microns. This seems the only way to insure those tolerances are maintained for each change of OLPF.
But screws are subject to human error. (For instance, over-tightening) It's hard to "screw up" a magnet. Pun intended.screws works for microns as all lenses have their mount screw on
Velcro is magnetic?Im sure if Jarred says screws are OK and they are moving to tooling quickly they KNOW screws work. I`m sure they have not been testing with Velcro.
Just an idea…
Cheers - #19
Velcro is magnetic?
By the way, I didn't say screws won't work. I just agreed with Blair that maybe magnets are a better solution?
We have different concerns.Velcro is like a hairy collotype. Not magnetic.
I`d rather they focused time on making an old OLPF that has good colour rather than worrying someone will destroy the screws on their camera. THAT would be priority number one for me. A old OLP with new PF colour. If a customer "screws up" the screws on the lens mount they have a problem too. There are other important screws we already use daily without a problem. These are quality metal screws not some soft metal from a Lowes or home depot.
4 screws similar to the lens mount and the screws already there if you look into your port hole on your dragon.
It needed to be screws as the filter needs to be flat as possible to the sensor for optical precision, snap-ins and push-fits don't accomplish that. Flatness is measured in microns when you are talking about focus planes so you want it to be solid.
I've lobbied Jarred for something easier to handle than screws - if that's what it needs to be optically stable then so be it. Don't anyone think this didn't get proper consideration.
The screws ARE small, but I've had them in and out over and over without issue. A precautionary degree of care is a wise thing to apply in any kind of proximity to the sensor - common sense will see you right.
About the only thing I'd continue to suggest is a little push-in plastic / rubber plug to cover the OLPF glass while you get busy with the tools.
John Marchant said:Sharpness up... But potential for moire and odd debayer artefacts.
Just thought I would give people a sneak peek on the Modular OLPF thats going to be available for Dragon soon.
There still people that prefer the old OLPF because even though skintones and highlight protection isn't as good as the new OLPF, they want a noise free image at higher ISOs that the old OLPF gives you by letting in more light. We of course will put whichever OLPF you want in your camera now... but the new OLPF module will make things alot easier to change.
The freedom and flexibility to make that kind of decision in different environments should be beneficial to everyone.. even if they only make the choice once and never change it again.
The Module install is pretty straight forward... we can do it or you can do it. Getting the old stuff out is the hardest part. The new "module" goes in easy and 4 little bolts and you are done. You dont need to touch any glass and you dont need to worry about putting it upside down or right side left. The front of the module is marked so you can see which one it is by just looking at the sensor so rental customers can quickly see which one is in camera.
At any rate... we are testing prototypes now and I expect these to be ready in 6-8 weeks after we get out of tooling. The OLPF Modules will be for sale in the store so you can choose whichever one you want or all of them and change at will. If you want to keep whatever OLPF you have in your camera right now you can still send us your camera and we can transfer your OLPF into a new module and send it back to you.
There will be 2 modules available out of the gate obviously ( The new OLPF and the OLD OLPF ) and IR PASS, ND, Clear and a few specialty ones will come after.
