David Rasberry
- Aug 20, 2008
I'm convinced, after trying many other options for on board audio (and not boomed or transmitter audio quality) that the M2D2 from Sonosax is as of today the best solution out there.
XLR for such a small camera are overkill, they choose to go TA3. This mini preamp has a ton of features and has also the ability to use a MS configuration and use a MIX menu where you can limit overloaded signal with a Limiter/compressor. I use it on my RED Weapon and Sony A7mkIII and never have to worry about sound level. The 132db of the M2D2 and the limiter give me freedom of mind. I set a limiter when it goes beyond -9db and then send the signal to the minjack of the camera.
Cleanest camera sound ever in a small package.
Patrick
PS: I could be biaised because my friend is the founder of Sonosax ;-) but I bet you know this company if you are in the sound industry.
No doubt an exceptional piece of kit. Not outrageously expensive given the quality, but still well north of $1k. Sound Devices Mixpre 3 supports feed to the camera as a mixer as well as internal recording with TC for about 2/3rds the price with accessories.
