Jeff Pedersen
I have decided to purchase this product based on the reviews of others and the research I have done. I already have my approved 512 SSD drive.
I called BMD but the sales rep was not much help to my detailed questions. sO I figured I would reach out to the guys on the front line.
Can those who are currently using the REd + BMD combo please give me some help?
Links to the cables that they are using to connect Red HD-sdi to BMD HD-sdi?
Also if you would chime in regarding any bugs, workarounds or general need to knows that a new owner of the hyperdeck should anticipate
I would greatly appreciate it.
Reports on the quality of 1080P image off the Scarlet?
Quality of 4K downconverted to 1080P vs. BMD pro res HQ off the SDI output.
Possible: Input SDI to Hyperdeck then output to HDMI and SDI simultaneously?
Timecode recorded properly, or any quirks?
Start and stop record confirmed working via SDI from the Scarlet?
Any news on the .r3d file naming feature being on the next firmware update?
Reports on the Crucial M4 512 SSD with HDS?
Can I take a 12v power off my v-mount battery mount and power this, or is it a proprietary 12v plug?
Does the deck have the ability to format the SSD or does that have to occur when plugged into a computer?
Fastest or most convenient ways you have found to offload files and format disks.
Thanks for any and all help.
