Christoffer Glans
Timecode, yes. Audio, no. But since Avid has AutoSync (unlike a certain Apple editing program), you can make WAV files using the original camera generated QT proxies, bring these into a bin with the picture files, select everything, and use AutoSync by time code to put them together (since they'll have matching time codes).
So if I output let's say 720p DNxHD files from an r3d file and after editing is done I'm exporting an EDL list, it's going to work for online editing?
As for audio, does any of the conversion softwares (redrushes, redalert, redcine) enable audio to stick around after transcoding?
Or is the process to get audio correct the same for all.
I think it's quite an unhealthy process to not have the audio stick with the video; why isn't this being enabled? Or will it be enabled in the next update of redcine?
