- Moderator
- #21
- Apr 19, 2007
- Los Angeles
- www.phfx.com
Hi Aleksandr, I've taken a look at the image and truly can't find any issue with it. You've under exposed which provides the low key look, which might be what was intended.
If you were aiming for a higher key exposure (or rather a balanced exposure), it is of course always best to attempt to get that in camera, but you can also grade this image fairly easily to "whatever" you want. This shot would land in the ISO 3200/4000 range for that, so you are 2 to 2.3 stops under if that was your intention and of course there would be noise if you are lifting any image that much.
If you are experiencing additional noise in Resolve, some have experienced that in the past. That's a resolve thing. I'd dig around and make sure your debayer resolution and all that is setup properly.
