Nicholas Teixeira
- Nov 10, 2011
- Age
- 35
- BRAZIL
- www.gridsuportes.com
yes, very easy to remove and apply...
Thanks Marc,Hi Nicholas, received mine today. Very, very nice product. I was a bit afraid because I have glasses (1,5 diopters) for reading, but it works great. Crisp, sharp image. I´m happy to leave my glasses at home now. You did a good job, thank you!
"Yes, I would recommend this to a friend".
Marc
here are some pictures explaining how to assemble ...how does the magnetic frame attach to the monitor
it is possible, but for that I would have to have the exact measurements of the monitor ...I borrowed a DP6 from prolifik films to test if a Grid 5.0 would work on it. There is some cropping of the outside edges if flushed to the monitor. The aspect ratio seems slightly different. It would be possible to use it, but you would have to rig a way to attach it. The magnetic piece that the viewfinder attaches to is smaller than the bezel on a DP6. You would see all the frame if you moved the viewfinder away from the monitor about 1/2 an inch, maybe less. Nicholas, you want to make us a piece for that?
