Justin Kirchhoff
- Dec 28, 2006
- Austin, TX
- www.digitalshakedown.com
What lens? Looks clean, all the way into the shadows.
old 50-150 or new, clean sheet 50-150, or is that just a rumour and the lens has not changed? just a little ot, but hey so am I.
Won't help you too much...
Jim
Do you have a full res TIFF of this shot? Some of what I'm seeing is probably just JPEG issues, so it would be good to take a look at the full res file.
Thanks!
Jim
What you should really ask for is the same shot on Build 15...
Jim
jim. i have a question i have not been able to find an answer to. i am applying a preset look to footage in redalert. When i Make a new _H proxy that proxy appears much darker than the image as i see it in redalert. i am using rec709 as my output LUT. i want to then throw the new proxy through my compressor droplet for the offline edit, but the issue is the blacks seem to really get crushed in the 'make new proxy' part of my workflow. what am i doing wrong???
Just curious, what kind of jpeg issues are you seeing?
Jim
david,
thanks for the info. i am guessing kona will have a solution soon that has .r3d built in. that would be sweet.
The problem is that Red Alert us not displaying information on the computer monitor in the rec 709 space. You are attempting to color correct on a computer monitor which does not display rec709 the way a broadcast monitor would. Many people run into this mistake when trying to do Final grades in FCP without a monitor which will display the correct color space.
