- Admin
- #21
- Dec 27, 2006
Remember the RED ONE has its own built in spot meter as well... which in reality can be much more practical and arguably more accurate, I know a few guys that swear by it.
If you see what we see in the REDalert grab when exposing then that's very good news.I set exposure while viewing REDspace in Build 16.
ISO 100 will be less noisy, but at the expense of range.
Well Spot and Incident regardless of calibration would return wildly different results if you had a black surface in sunlight and a white surface in shadow. Which I believe was the source of Chris' question.![]()
ISO 100 will put your 18% grey very high in the RAW with very little headroom above 90% white. At ISO 100, you're trading your highlight range for shadow range.
The compression approach has/is changing.
I'd certainly encourage you to shoot at ISO 400 or 500 for a high contrast scene. ISO 100 will be less noisy, but at the expense of range.
Jim
Changing ISO is really changing where you place, in the range of 0-4095 code values, where mid grey goes. ISO100 will put the mid grey high up that range, and hence, there are few code values left for highlights. You are essentially trading less highlight lattitude for more shadow lattitude (ie, a noise free image). However, if there are shadows in that scene, you'll be able to dig further into them.
If you go to a higher ISO, you start adding highlight lattitude for noise / shadow lattitude. Say you now go up two stops to ISO400. Now you've gained two stops more highlight lattitude, but you've lost two stops on how deep you can dig into the shadows.
Graeme
