Ivan Cortazar
Here the correct way.
MXO2 with Color, if you are grading R3D, apply 0.810810 to the master gamma while you grade, then upon rendering to DPX, take this away. If you are rendering to YUV QT then burn that master gamma in, so keep the 0.810810 value then render.
Sorry about the mistake.
Great!, Thanks a lot Kaku, now the whole world makes sense!! Finally I understand it. I also made a DVD and it is pretty much the same as the MXO2 monitor. A bit darker, but that could be the TV set or the Mpeg2 encoding. I'm in no close situation to have a perfect color grading station, but it feels good to know at least what to expect and how to adjust if needed.
