Sam Roberts
I am new to FCP and new to AJA gear and am in the process of setting up my editing system.
I have a clip shot in 2k and transcoded to a quicktime movie scaled to 1920x1080 using the ProRes codec using Red Rushes.
I am outputting from the FCP timeline into the AJA iOHD and then through an HDMI cable to a new Panasonic 1080P plasma.
In FCP I have a sequence preset set to AJA iO HD 1080p 24 Apple ProRes 422 (HQ) and my video playback is set to AJA iO HD 1080p 24 ProRes 422.
In the FCP VIEW menu the settings are: external video all frames. Video playback AJA iO HD 1080p 24 ProRes 422.
The shots in the sequence properties are: size 1GB Vid rate 24fps frame size 1920x1080. Compressor Apple ProRes 422.
All shots on the timeline have been rendered
The problem is when I monitor the timeline output 1/3 of the screen is a black bar with the shot itself shoved over to the right of the screen with only the first 2/3 of the shot visible (see photo below)
If I switch the playback output to 1080i the picture becomes normal and it moves as I scrub, but I can't get any real time playback.
Any ideas? Thanks.
Any ideas? Thanks.
