emil_h
Hey guys any suggestion on who makes the fastest V-Mount charger? I currently own the Switronix version and it's slow as balls.
problem is not the charger, but you can not charge normal V-mount batteries faster than 2-4h or you kill the cells in the battery.
For any useful answers it would help to know what size batteries you are using and some other reference to quantify "Slow as Balls"...:thumbsup:
What do you define as normal v-mount batteries? Are there any that don't fall under that category? Also, I've been told that there's definitely a large difference between say a 200 vs a 1000 dollar charger in terms of charging speed.
For a day shoot I get by with 2x 160wh. 160wh, I get roughly 2h15min shoot time.
Charging time from 20% discharged to 80% in about 1h20min. Full in 2h20min.
This is typical for most cine batteries - some manufactures even limit the % of discharge / Charge status (20/80%) in order to pretend your battery ist charged fast..... but in the end your 160Wh battery really only has around 110Wh USABLE Watts
That's why it is recommended to use the charger advised from the batterie manufacture - the charger is usually programmed in a way to get the max life out of your cells. Depending on the actual cell used in the battery, ambient temp, ect,ect. You get more or less out of your battery. For example, most batterie Cells don't like charging below 10°C and charging them to the last 100% sometimes also shortens Cell life.....
