Brian Pascale
- Nov 10, 2011
- Silver Spring, Maryland
- www.hiptv.com
Hope these issues can be resolved. I am thinking of buying this but need it to be working properly.
Mark, is there a link out there for firmware upgrade? Need it fast
Noted for coming firmware update.When adjusting display, menu overlay should be out of the way.
Also noted for future accessories.attachable 1-2" (adjustable) deep hood extension for those sunny days when you don't want to go with the loop or you're op'ing a gimbal. This will make it a hit amongst MOVI/RONIN folks
So I updated the firmware.
The good news.
- preset buttons 1 through 4 work as intended assignable to the most common functions
- works great in REC 709 or most standard LUTs
- All functions (peaking, 1:1, vector, histo, blue burst, false color, etc work great.
- Very solid HDMI / SDI connections
- HDMI to SDI conversions works great
- D Tap to 4 pin connection well built and works
The not so good news.
- When trying to calibrate to color bars, the ghosted display is still over most the picture making calibration difficult but not impossible. You still have to set a parameter, exit out of menu to look at it, then go back in to adjust, repeat.
- The menu has a selection for "Waveform". But it's really just a histogram. Though a waveform is in the works. Histo works fine.
- When calibrating to color bars, I had to boost the chroma to 100 % full settings to get proper balance on my color bars in blue burst. Worked but considering the factory setting is way too low at 69.
- Mosquito noise is huge when underexposing in log (only tested S Log which is amongst the flattest). Will test in C Log this week on Amira.
Recommendations
- When adjusting display, menu overlay should be out of the way.
- Not sure anything can be done about the the excessive noise in dark areas in Log.
- The ability to load in LUTs or minimally have a Rec 709 LUT option that we can put in the pre-set buttons
- Waveform can't arrive too soon
- attachable 1-2" (adjustable) deep hood extension for those sunny days when you don't want to go with the loop or you're op'ing a gimbal. This will make it a hit amongst MOVI/RONIN folks.
Will I keep it?
Hell yes. It's the only 4.3" 720p monitor out there with HDMI to SDI conversion (it works flawlessly) as well as SDI and HDMI loop through. The pic quality in REC 709 (and most other pic profiles) is outstanding. It has excellent feature set. Build quality is tank like but not heavy (better than small HD's). Unlike the Small HD 4.3" the loupe doesn't distort. It's perfect for gimbal operation. Small built in hood is great for most use. It has real buttons for main functions. Has Arri rosette on the side for EVF style mounting. Runs about 2-3 hours off on small Sony NP.
If noise isn't an issue in Red Raw than this is a no brainer for many on this forum.
Also, considering how quick Mark was to respond with the new firmware, this bodes well for customer service as well as updates.
Ned thanks for really diving in extensively. Drives me crazy when people say a $1500 piece of kit "looks good" and leaves the rest up to interpretation, expecting others to make a solid decision.
So, being a 058W TVLogic and Alphatron owner, how does this guy compare for Run and Gun work? I love the TVLogic as a focus puller and the Alphatron has served me well as an Op but I wouldn't mind a new addition if it fills some gaps.
Hope the firmware updates continue to shine.
For run n gun I love it. TV logic is an excellent and small monitor. But I needed something smaller for doc and gimbal work. An EVF like Alphatron doesn't cut it for me. I don't find them sharp enough for critical focus. You'll find this plenty sharp and big enough to flip up the EVF for monitor style operating. I too have a 5.6" Small HD. I've relegated that to my AC for gimbal work. One man run and gun, I take the F&V. As an EVF, it works well but albeit bulkier than Zacuto or Alphatron, but way sharper and more versatile. Buildwise, it's in a different league.
Also, I've been in personal communication with the developer and they've been most responsive. Reminds me of Nebtek in the early days.
They're the same rez spec but Gratical is a dedicated EVF, not a dual purpose deal like the F&V. I would hope at the Gratical's price it's as good or better as an EVF. Until I look through it, I can't compare. But then again Zacuto's first EVF is dead to me for any use. I actually replaced that on a job with a Small HD 4.3/Loupe even through the Small HD's rez spec was lower. It was just a better/clearer image for focus.Do you think its sharper than the zacuto gratical?
