EXT port will not accept Lemo
jake southard
Beverly Hills, CA
www.jakesouthard.net
Today, my V-Raptor EXT port would not accept the Lemo for timecode sync. The cable wouldn't fully seat into the port to give me the "click". It just kinda went about 80% of the way in, then stopped. Looks like there is something blocking one of the top holes, which doesn't make sense because i'm the only one who uses this port with my own cable, and all my cable's pins are in tact. No broken pins.
I use this port semi-frequently and always use my own cable, so i'm not sure what the heck could've happened to block this hole. Worked fine a week ago
Click image for larger version  Name:	IMG_5441.jpg Views:	0 Size:	121.7 KB ID:	3803297 Click image for larger version  Name:	IMG_5441.jpg Views:	0 Size:	121.7 KB ID:	3803297
That looks very much like a broken off pin from being too aggressive plugging or unplugging.
that would make sense to me if my cable had a broken pin in it
Honestly something looks off with the whole socket like the contacts have been pushed back through the insulator. I don't have the camera so I can't compare it. Maybe that hole got crimped some how and pushing it collapsed the hole?
edited for clarity
