however I would never use uneven numbers for frame size, some softwares cant handle that. Some quickitime applications for example. So I would actually do 4096x1706
2k widescreen DCI specs are 2048 x 858 pixels.
There are no DCI specs for 3K.
There is no exact rule for 1080p widescreen because it is always 1920 x 1080 with bars on the top and buttom.
