Lakis Amarantithis
I use the Epic with Sound Devices MixPre-D and Sennheiser EK/SK 100 G3 for scratch sound or for cases the sound does not need to be as good as my 788t because is convenient not to have to sync sound.
I recorded sound both with the MixPre-D and without it (meaning straight to the Epic through the W00d3n Cam3ra A-Box).
The sound that I get from the Sennheiser connected straight to the camera without the MixPre-D is cleaner!!
Am I doing something wrong? I got the Mix-Pre-D because I read the preamps on it are fantastic and it helps.
I set the Sensitvity on the transmitter at -21dB, set AF out of the receiver to -18dB. The Epic input sliders should be at the bottom. No more amplification is required.
Also : The W00d3n Cam3ra A-box works well for this unit, with the camera's preamp inputs set to balanced.
No phantom power required (obviously).
as Paul Russell advised here:
http://www.reduser.net/forum/showthread.php?94487-Epic-Sennheiser-G3-Audio-advice/page2
Thanks!
Thanks!
