Zeb B
Heh heh sorry... That's mine.![]()
A patient dog gets it way. Sooner or later you will leave the door open and the steak on the table . . . I will be patient . . .
Heh heh I should let you guys test stuff more often.. this is great. Good job Tim.
Sure... if you have 2 Epics bolted together for 3D shooting, one of the SSD modules would be pretty challenging to get to.whats up with the rear ssd module in that pic? any benefits over using the side module?
what does this weigh, because with the quick start up time of the epic, do you really need this? seems kinda a waste of money. + it only takes redvolts, which dont work with anything else. Kinda don't see the need to switch from V lock's
...2012 better not be the end... I got too many cool toys to play with and learn!
So what about powering accessories: follow focus, transmitters, cinetape?
Wouldn't a power out connector make sense on the quad module, or is it included? (can't see any on the pictures)
I know that a single redvolt might struggle powering anything else besides the Epic, but 4 in parallel should be able to power additional items.
If you don't mind constantly swapping the Volts every 20 minutes all day long, then you don't need it.
this is a very god point. In most of our setups, we would need a brick to power the WFF, and other accessories, or sometimes an ENG lens for 2k sports....
a couple of 12v lemos, and/or a p-tap would be great on this module. (hate p-tap, but useful)
Im sure the proI/O will have something, but for some configs - this setup might be all you need.
Hi Tim,
Forgive my ignorance but am I understanding that the volts in the quad module drain one at a time? So as one depletes it automatically jumps to another one making it hot swappable?
Thanks, p
Pure FUD. 4 Volts will run well over an hour and while you change those 4 out, the 1 Volt in the handle allows you to take 20 minutes to swap out the 4 Volts and keep shooting!
You can also accomplish this with the V Mount and the Side Handle Volt.
CHOICES and CHOICES - but a Quad Module does NOT mean you are changing Volts every 20 minutes that is silly- unless you only want to swap out the one that drains? Why would anyone do that?
Yes, Jarred has stated December availability.Will there be a double battery module available allowing for a shorter millipede?
Hi Jarred and Tim,
Cool system - I like the way the RVXL's and the RV's can play together.
If it's not a big secret could we get an indication of how to calculate the cameras dimensions based on what modules we are planning to use ? I was planning on getting some hard cases made this week and would like to get it as close as possible. Pro I/O Module too.
Thanks,
Matt Uhry
www.mattuhry.com
We are all friends here but I just want people to be sensitive to posting things like "If you want to swap batteries every 20 minutes, get the quad module" when that is blatantly NOT true.
That wasn't what was posted. The guy posted, in response to someone asking why one would want the quad module: "if you are willing to swap batteries every 20 minutes, you don't need the quad module". His point being that using the side handle requires frequent battery changes, but using the quad does not. There wasn't any FUD, it was just that people mis-read his posting.
At least that how I read his post when I first saw it.
