Robert Hart
- Feb 26, 2012
Edited in view of overlapping reply.
Against backreflection on a viewscreen coming in under a brolly, assuming you had one for shade over the operator, with the display showing a raw image, it would not be too hard to miss the IR colour cast.
As for "well no s**t dumbass" expectations, you are not going to get that expression from me. My guess that due to the schedule and the intense pressures involved you ended up with a camel-building committee of persons who each had enough knowing to work the problem to a solution over time in a more conducive environment. Sometimes in a collective circumstance, there evolves almost a barrier of denial of the obvious because - "Hey, the other guys are smart, have the knowing and will already have factored this problem out, so it MUST be something else."
Leave the self-flagellation and personaol blood-letting to the more extreme medieval Christian sects, Shi-ite Islam and maybe some others in there as well. Having evneutally worked the problem and learned, you have better things to look forward to.
If it comes to the worst, maybe you will have to find an excuse to creatively desaturate the footage to black and white here and there.
