Mark Britton
A good snap of sticks will register, but other than that, too low for synching without phantom power, at least.
I have to ask-
with a mike mounted directly into the jack, how much FAN noise is it picking up?! I mean, its right beside the fan intake isn't it? I would think it might be useless as a wild sound mic, tho maybe for sync-ing...
Stu Aull
Alaska
Ah-The fan turns off when shooting.
Ah-
My understanding was the fan just slowed down, not shut off completely....
Stu Aull
Alaska
Phantom power is not going to make this Sony mic work better. That sony mic uses BIAS power, not phantom power. It's also stereo. With Bias power, the voltage differential is between the sleeve (ground) and each of the the tip (left channel) and ring (right channel). With phantom power the voltage differential is between tip and ring. With phantom power turned on it should make this Sony mic work worse or not at all.
RED had prototypes of phantom powered button mics a year or so ago. I don't know if those were just mock-ups or working units. Would be nice to know what happened to them.
