Dynacore Mini series battery for Red
Mendel,
While I'm not sure where Peter got his from I did contact Ari at Omega Broadcast who quickly responded to my queries. I'd recommend giving Ari a message and seeing if they could help you out.
Happy New Year everyone, in the new year Dynacore will launch more new product, we will provide the best service for you~
Now, we will promote our new Mini series batteries, D-200MS/A, with higher capacity(14.8V&200WH) and keep the small size and equip with the D-TAP&USB output. Now you can book them from your local dealer and you can get a special discount for the new product~
Of course, if you need, we had the special version that can communicate to RED cameras.
cheers
Jerry
Now, we will promote our new Mini series batteries, D-200MS/A, with higher capacity(14.8V&200WH) and keep the small size(127*88*76mm) and equip with the D-TAP&USB output. Now you can book them from your local dealer and you can get a special discount for the new product~
cheers
Jerry
Those are great news! I love my mini's. I have a small suggestion though, or a dream :-) , would you consider doing this 200Wh battery split into half? So you basically have two 100Wh batteries and this way you can fly with it? Some companies offer split batterie, but not in mini size.
Zou Shijie, can a Dynacore D-200MA battery only charge on Dynacore chargers or will any gold mount charger work? I ask because I own 2 Anton Bauer Q-2702 and 1 Comer BC-C2A and seeing if these are compatible.
What weight is the D-200MA battery?
Hi Oron, Happy New Year and thanks for your suggestion, yes, in the new year we will do it, hope we can promote it soon~
What are the differences between D-200MA and D-200MS ?
EDIT: Ah, just realized it's the mounting types!
Hi Audy, yes, just the mounting is different, A means gold mount and S means V mount~
Hi Eric, Happy New Year, now Anton Bauer chargers cannot charge our batteries, sorry for this, and the weight of D-200MS/A is around 1KG~
HI Zou,
Did you ever release the DM-155 v-mounts with percentage RED cameras can see? Are they sold in the US?
HI Zou,
Hi Brendan, yes, could you please contact our dealer in the US directly, here is their information:
sales@omegabroadcast.com
OMEGA BROADCAST GROUP
817 W Howard Ln
Austin , TX 78753
T : (512)251-7778
F : (512)251-8633
attached the specs for your reference:
capacity: 200WH
Weight: 1kg
USB output: 5V/2A
Max output:220W/18A
My Dynacore showed voltage on my Raven (WC cableless AB adapter). Now, same set up with a Scarlet W don't have any info at all.
Anyone lost his voltage recently?
This is because of the WC cable-less adaptor, not Dynacore. Please search all over the forums - there's tons of talk about this.
