DSMC2 PROTEUS ll Master Module by ActionProducts
Just as I've recently (Xmas) got a Proteus MK1 for my Dragon (alongside XLR audio & V mount unit)... and awaiting original Electra, Apollo, EVF mounts, rodmount audio, riser plates (and a few more plates/cables etc).
Guess my timing was off (as always, LOL).
How do all the new MK2 versions work wit the Dragon?
The PROTEUS ll and APOLLO ll only need a simple adapter plate. The CALYPSO ll mounts directly.
Yes, you can "dock" whatever fits in (COLR, BOLT, ECLIPSE, .....)
We will be at NAB
Looks very interesting (also looks a little way off but I might be wrong)
... Is the white TX module occupying a space that could contain a bolt 2000 or similar?
Is that space a 3rd party Dock accessory slot?
Ps will you be at the UK BSC show?
Do you plan on doing just a plate ?
While it's perfect for now for my weapon, I have to think of my Scarlet too, and I'm working with a paralinx arrow with your arrow module that I would love to keep.
Just a plate with a clearance for the usb cable would be nice too. (I would do the lemo>usb mod myself)
Can this be put directly on the back of weapon or must you have a module like the base expander to connect?
are you using the module that bolts directly to the camera back? or the one with SDI to HDMI?
3. "PROTEUS ll - LCS / ACN" Master module - Open System
For EPIC / WEAPON / SCARLET / RAVEN
-2x Balanced Audio inputs (3-Pin, full size XLR female)
-48v Phantom power
-DC IN (6-Pin 1B LEMO socket)
-DC IN (4-Pin XLR socket)
-3pin Fisher RS-SS/GPI, 1.5 A
-3pin Fisher RS-SS/GPO, 1.5 A
-5pin Lemo (TC / RS-232 Rx and Tx)
-Stereo Headphone output (3.5 mm jack)
-HDMI 1.2 output (Type A socket), 60 Hz max frame rate (via 3rd party Dock accessory)
-USB Power output (Type A socket), 1.5 A
-1 x 3G-SDI output (75 Ω BNC), 60 Hz max frame rate (via 3rd party Dock accessory)
-Hot Swap between Studio power and Battery mount
Options:
-V-Mount / AB / RED-Volt interface
-3 Motor / Nikon/Canon LCS (or check out APOLLO ll - LCS top plate)
-Ambient ACN TC Generator with Genloc
-Genlock input (75 Ω BNC)
-RED EPIC version
-XLR for PWR (change XLR input to various PWR options)
-more to come
"BATTLESHIP" components http://www.reduser.net/forum/showthread.php?139566-ActionProducts-quot-Battleship-quot-(for-WEAPON)
Hi Brian, the power output is to low to feed a remote focus!
Otherwise it would be perfect😉
Best Robert
