DSMC Release Build v6.3.27 and RCX Build 41 and Photoshop Plugin ( Helium)
Jarred Land
Fire Chief
Staff member
enjoy.
SIGNIFICANT CHANGES SINCE PREVIOUS BUILD v6.3.17:
Added WEAPON S35 HELIUM sensor support
Added WEAPON 8K VV DRAGON sensor support
Added WEAPON 8K VV Anamorphic DRAGON sensor support
Added DSMC2 REDVOLT Expander support
Added DSMC2 V-Lock Battery Module support
Added DSMC2 JETPACK-SDI Expander support
Added REDMOTE v9.6.28 (DSMC only)
Fixed WEAPON 8K VV black sun artifact (DSMC2 only)
Fixed Apple ProRes playback with 4 channels of audio (DSMC2 only)
Fixed Apple ProRes playback audio synchronization (DSMC2 only)
Fixed incorrect Apple ProRes frame rate in Open Gate mode (DSMC2 only)
Fixed magnify issue with Apple ProRes 4444 and 444XQ (DSMC2 only)
Fixed framed overlay/auto hide menus for mirrored monitor
Fixed random cursor movement in playlist moving multiple clips
Fixed camera freeze in playback with auto-hide menu and custom overlay
Fixed blank RED Touch 7" LCD on startup
Fixed record start failure with HDRx at 2K WS 1fps
Fixed invalid Power In information after battery swap
RCX Build 41:
REDCINE-X Professional Build 41 Release
* Added: 8K Helium sensor support.
* Added: Controls for camera record mode and record mode options for R3D tethered streaming.
* Added: Ability to create a new clip for every frame trigger when tethered streaming in Frame Trigger mode.
* Added: RED Tether command line argument (-c) to automatically connect to a camera and begin recording when launched.
* Added: New Transfers view to show info on your current, pending, and completed tethered file transfers.
* Added: Ability to cancel pending and in-progress tethered file transfers.
* Added: OpenCL support for Intel Graphics. (Requires Intel Graphics Driver 4416 or newer)
* Improved: Video Playback performance.
* Fixed: Issue on Windows where a console window would pop during some exports.
* Fixed: Crash when selecting text in Burn In export settings.
* Fixed: Crash on first run of RCX.
* Fixed: Random lockup when disabling RRX.
* Fixed: OpenCL Monochrome decodes at lower decode qualities.
* Fixed: Video Playback PBO error.
Photoshop Plugin Build 16
* Added: HELIUM Sensor Support.
* Added: Support for Photoshop 2015.5.
* Miscellaneous bug fixes and updates.
WEAPON 6K/8K: https://www.red.com/downloads/55a01322f01b305ec100179a
WEAPON (MG ONLY): https://www.red.com/downloads/56af8a8ccc11fa5a1b0020a4
SCARLET-W: https://www.red.com/downloads/56af8ace2325b449230020b0
RED RAVEN: https://www.red.com/downloads/56af8b709bf7e832280022aa
EPIC DRAGON: https://www.red.com/downloads/52b4914517ef02624c000017
EPIC M-X: https://www.red.com/downloads/4f56854e6261f95a5700069b
SCARLET DRAGON: https://www.red.com/downloads/538b61b52f74a95b28001816
SCARLET M-X: https://www.red.com/downloads/4f56854e6261f95a570006ca
REDMOTE: https://www.red.com/downloads/4fd907a426465a310b00015c
REDLINK SDK : https://www.red.com/downloads/533c9a8226465a0b61000996
DSMC Toolkit: https://www.red.com/downloads/4fd9080e2f74a94f73000139
REDCINE-X PRO: https://www.red.com/downloads/5340c33e26465a4b46002ddc
RED ROCKET-X Installer: https://www.red.com/downloads/5340bfdd26465a5218000c41
Adobe Photoshop Plugin: https://www.red.com/downloads/508ebcee17ef022b21000558
the timing on this couldn't be any more perfect... THANK YOU!
thank you for the constant updates and improvements, which are FREE!
RED is the best
Strange issue for me with audio on my Epic Dragon. I have an Olympus dictation mic plugged into one of the front inputs for scratch track. Now if I plug into ch1 it appears on ch2, and vice versa.
This happened for me on the last build as well. Anyone else notice this?
Is "improved video playback" under OpenCL or CUDA or both?
Do mac users have to worry about having Intel 4416 driver or does that shit get auto-updated with the OSX updates? (though I'd gather that dedicated graphics are still way better... unless you could leverage both GPUs simultaneously.)
Yep, same as last build.
I haven't tried this new build yet but I did have that issue on the last build too, really threw me off at first before I realized what was going on.
The Video Playback improvement is in the viewer code itself so it will help both OpenCL and Cuda users.
Intel drivers do tend to get updated with OS updates.
Yes, you can enable both graphics cards for OpenCL at once.
