DSMC NAB Build 6.3.6 - AVID DNXHR and DNXHD recording.
Jarred Land
Fire Chief
Staff member
a TON of really great new features in this one... this is one of those " It's like a whole new camera " builds.
I really screwed over our RED.COM team today by releasing all this two days before we were supposed to so it wont be till monday morning for the links to come live but I wanted to lay down the path since some of our 3rd parties are relying on this news to release theirs.
Enjoy.
SIGNIFICANT CHANGES SINCE PREVIOUS BUILD v6.2.55
* Added Avid DNxHD/HR Codec support (DSMC2 only)
* Added Apple ProRes playback (DSMC2 only)
* Added Apple ProRes support for FF format (DSMC2 only)
* Added tethered Apple ProRes (DSMC2 only w/ REDVOLT Expander or other gigabit Ethernet compatible module)
* Added high speed file transfer over gigabit Ethernet (DSMC DRAGON, DSMC2)
* Added 3rd party OLPF name and default calibration (DSMC2 only)
* Added control for default curve in split monitoring (DSMC2 only)
* Added REDCAST Module dialog notification when non-UHD format selected (DSMC only)
* Added REDMOTE v9.6.23 (DSMC only)
* Added RCP pass-through support
* Added Lens Info tab to Lens Dialog
* Added Atomos device support to HDMI output
* Added Metadata tab in Lens dialog for manual entry
* Added shortcut assignments to presets
* Added Canon EF 70-300mm f/4-5.6 IS USM
* Added Canon EF-S 18-55mm f3.5-5.6 IS II
* Added Nikon 200-500mm f/5.6E ED AF-S VR
* Added Nikon TC-14 III 1.4x Teleconverter
* Added Sigma 120-300mm f/2.8 DG OS HSM A1 for Canon
* Added Sigma 24-35mm EF for Canon
* Added Sigma 70-200mm f/2.8 APO EX DG HSM OS for Canon
* Added Sigma 24-105mm F/4 DG OS HSM for Canon
* Added Tamron SP 15-30mm f/2.8 Di VC USD for Canon
* Added Tamron SP 70-200mm f/2.8 Di VC USD for Canon
* Added Tamron 28-300mm f3.5-6.3 Macro for Canon
* Fixed Motion Mount settings after power cycle
* Fixed Motion Mount shutter angle spinner values
* Fixed Motion Mount shutter speed with Square or Soft shutter
* Fixed REDMOTE lockout when SLA is displayed
* Fixed timelapse timer when frame count is larger than 1
* Fixed tint value for Auto White Balance
* Fixed PRO I/O Preview (PVW) abbreviation in UI (DSMC only)
* Fixed distorted live audio after playback (DSMC2 only)
* Fixed color and gamma space values in QT metadata (DSMC2 only)
* Removed Lens Calibration menu
* Improved Nikon/Canon lens support
* Improved PL Fujinon/Canon lens support
* Updated in-camera help files
You are The best !!! So now scarlet e can record prores 4K and 5k ?
Oooooiooooooooooooooo!!! Can we offload and backup from a redmag in-between takes?
I can't wait to test out the DNxHD/HR support. And 5K ProRes sounds intriguing!
ProRes Playback on camera is massive. I've already seen DSMC2 bodies put to ENG use just firing off ProRes only shooting days. This will help that world out a whole bunch.
Somebody just pinged me for a stop motion project and I can see some potential for the new ethernet transfer support for something like that. Hell, timelapse too for that matter. I already know the fashion folks are going to eat this up.
ProRes playback - awesome! And a 5k gift as well... Also been noticing great improvements to Weapon boot time.. Will the inclusion of additional Avid codecs etc potentially affect this or will we keep seeing it head south towards faster?
not 5k prores recording, FF sensor recording which means when you are in 4/5k FF modes on your camera you can record scaled down ProRes, before you couldn't in that aspect ratio :)
So does that mean the REVOLT Expander could deliver a 4K ProRes stream over ethernet? Seems like that would make it a DSMC2 REDCast module of sorts. With the right software (Probably not made yet) and a couple cameras could you theoretically do a 4K multicam/live stream with a router?
THANK YOU FOR PRORES PLAYBACK!
Once again a big thank you to Red.
Do we know if this will work with The Nikon Mount and lenses ? I'm still on 6.0.44 (which rocks as a build anyway) on my Epic and Scarlett Dragons. Lots of Nikon users are waiting, is now the time to upgrade firmware?
lastly, Thanks so much to Red for continuously pushing things forward......
i hope this gives us the ability to add dumb lens info to r3d metadata.
david
A question though, because I've been pushing for this a while now; is it DNxHR/HD in MXF form? Because DNxHR and HD is just like ProRes really, there's no real difference within Avid or any other software. If it's MXF OPatom, that is the real deal for Avid editorials.
