- Moderator
- #1
- Apr 19, 2007
- Los Angeles
- www.phfx.com
Well this felt like a Monday
So one of the things I've been seeing and hearing is how many folks who don't fully understand the new DSMC Fan 2.0 Kit and what it does. Another crazy thing is I've found recently when rigging up some cameras that some folks don't know about the new Adaptive Fan Algorithm. Which alludes to folks also not upgrading their firmware for some time. I'm now working with one major rental house to get all that cleared up because that's just nuts.
Onto the stuff. And this only relates to Red Epic Dragon.
Testing Details
- Audio Meters Used: Several Class 2 and Class 1 Meters, Brüel & Kjær 2250 was "the best one". Also utilized a Samsung S4 app which had impressive sensitivity.
- Meters were "on axis" to loudest potential point of the Bottom Fan.
- Variance Between Meters Readings = < 1dB (not really an issue)
- Room Size and Info: 5x8' Small Room, tile floors, no sound dampening.
- Tested 12", 3', and 5' distances. Measured from Focus Plane Mark w/ and w/out lens on.
- Roll Times Tested = 3, 5, 10 minute takes.
- Room Tone Measured at 26dB
- Room Temperature 78°
FAN MODE: Adaptive - Performance
** Adaptive Fan Mode uses an algorithm to adjust the speed of the Bottom Fan to try and maintain a user selected sensor operating temperature (this of course should match your Black Shade calibration temperature). A higher temperature may take longer for the sensor to heat up and start shooting. Lower temperature the opposite. Currently Red defaults the Epic Dragon Fan Mode using Adaptive at 65°, which is a good balance between start-up to targeted Black Shade sensor temperature and reasonably quiet camera operation. At 65° and 70° Red Epic Dragon is actually quieter than other cameras now.
Measured at 12":
- 55° - Typical Operating Range = 56-61dB
- 65° - Typical Operating Range = 40-46dB
- 70° - Typical Operating Range = 35-45dB
** I personally have been running at the default Adaptive 65° with the new fans lately. Initially I started at 70°, but I have switched as testing with standard shotgun microphones and recorders has produced decent results at that dB range. Know that you can squeak out a bit more of a quiet camera if necessary running at 70° though.
Default Adaptive 65° at notable lengths:
- 1 Foot = 40-46dB
- 3 Feet = 31dB
- 5 Feet = 30dB
** A note on fans. Some have noticed the new DSMC 2.0 Bottom Fan sounds different than the version 1.0 Fan. This is true. The 2.0 Fan is bigger, more powerful, and pushes more air through to cool the camera core and sensor faster. It can be potentially louder at moments (and we're talking minimal dB here), but will cool down the camera faster. The Bottom Fan itself is the most important part of the Adaptive Fan Mode as that is what is changing speed to adjust to various temperature levels.
** The DSMC Top Fan 2.0 Produces less noise than the Bottom Fan and is integrated with the algorithms though isn't as "blowy" as the new Bottom Fan when actively cooling. You will feel heat emanating from the Top Fan as warm air is pushed out. This is normal.
** Dragon does indeed run a bit warmer overall as a camera system. You will notice the camera body being warm to the tough. Also normal.
FAN MODE: Adaptive Preview Quiet Record - Performance
** Adaptive Preview Quiet Record allows you to specify a sensor temperature and "cut" the fan speed by a percentage range of 25-100%. You can also select a Post Record Delay of 10 seconds, 30 seconds, and 1 minute.
** In comparison to Adaptive mode at 65° which ran at 40-46dB, Adaptive Preview Quiet Record goes as low as 30dB at that same 12" measured distance. Which would be useful for extreme closeups while rolling dialogue for instance.
Audio Sample
I have previously recorded a sample of the new fans in action. I am quoting that post here as it's informative.
One other tidbit. We tested a layered neoprene stack and foam with both plastic and aluminum backings to absorb and terminate sound a bit more. This typically cut 4-5dB off at 12". So if necessary that is possible. If you needs something super duper quiet (meaning generating no noise) at the moment a blimp would be ideal. The absorption stack we used was actually modeled off of what the Jacobson Soundblimps have been using for a long time now. If a full housing was made of this material with proper ventilation you would have a dead silent camera.
That's all my notes for now. I know a few wanted some hard numbers. Here they are.
Hope this helps.
Testing Details
Measured at 12":
- 1 Foot = 40-46dB
- 3 Feet = 31dB
- 5 Feet = 30dB
Audio Sample
Alrighty. Finally had a moment to record a bit of a sample of what the fans sound like in "practical" use. Meaning with a decent shotgun mic and recorder that would be used on set.
Here's an MP3 file for you to download:
http://www.artbyphil.com/temp/reduser/phfx_DSMCFAN2pointOSounds.mp3
Details:
- Red Epic w/ Mysterium-X
- Fan setting = Adaptive @ 70°C
- Sennheiser MKH-416 Shotgun Mic (on boom pole)
- Zaxcom Maxx Audio Recorder/Mixer
- Increased sample by about 9.9dB to really reveal subtle sounds.
- Room size = 20x25-ish with a bit of reverb, matted floor mats on wooden panels.
- Room temperature = approximately 83-85° fahrenheit, no fans or A/C on to contaminate the sample.
There's been a lot of confusion regarding these fans, but hopefully this real world test clears up all that stuff. I've been shooting with the new fans installed and really it's a huge improvement.
As the audio sample states using the new fan algorithms and the new fans is where the increased performance is most noticeable.
Also, I should note based on my observations that on a typical shooting day the new DSMC Top Plate 2.0 acts somewhat like a heat sync and helps to dissipate/absorb heat.
Hope this helps.
