DJI Ronin wireless video 1 ft away to help balance? Yey or ney?
Lee M
I have a Dragon hooked up on a Ronin with zero wires coming out of it. I am actually using a Teradek wireless transmitter to send the video from the Dragon to a Shogun mounted on the handlebar (zero latency) just 1 ft away instead of mounting the Red Touch via a wire. Only annoying part is having to connect the red touch monitor to change some settings as my hotlink and redmote are not the most reliable but I figure once its set I won't need to do much else on the monitor.
I am doing some shots that require the Camera to point all the way downwards and find that having the wire would cause the balancing to be a bit off and it would flake out unless I really had it balanced good. I guess another plus is not draining the Dragon battery as fast by powering the LCD through it.
Is this overkill? Is there another way of connecting the Red Touch monitor to the Dragon without effecting the balance too much? I have a RED 18" LCD cable but it's pretty thick. Would love to hear some input.
could you ditch the monitor and use the a sidekick and foolcontrol instead?
steve
I have the hotlink with fool control but disconnected it since it keeps disconnecting from wifi, going to have to troubleshoot it. Need the monitor to see what I am shooting but I could use the wireless receiver for the focus puller instead of receiving a signal from a foot away :) Rather than spending $1000 on a second receiver.
Why not use the DJI SRW-60? It's designed for exactly what your doing and only cost $250
