- Thread starter
- #21
Scott Lamoreaux
I personally don't know if you would need to update the firmware, maybe? I would say that's a last ditch though.
I also think having DJI test on a DSMC1 camera is not the best way to solve as they're using a different system with slightly different power-draw. What is good is that the system is technically working overall.
I might suggest getting the cam to power via AC, then unplugging AC and plugging in your Ronin brick setup. Just trying to narrow down as much as possible and focus on what the issue could be.
Definitely give those Switronix bricks a try via D-Tap. That should really help.
I feel so invested now....I want to know what is wrong! haha
Well,l I received the cable and power distributor back from DJI today and I'm not crazy after all - Still not working.
I compiled a little video to show whats going on.
I show that I'm using the AC Wall Power First to show that the expander does work when there is power coming into the camera via the LEMO input.
I attempt to use a full brick battery with the DJI cable to power the camera - No luck
I attempt lastly to use a full DJI battery via the Power Distributor - No luck
So it's either the Cable or something wrong with the V-Lock Expander on my Scarlet-W
I'm stumped - seriously.
Here is the video: https://vimeo.com/180960756
